Universal M18 Heat Exchanger Replacement
12
- - Pasadena Md
Can anyone provide a source for a reasonably priced heat exchanger for my Universal M18? I would like to move up to a 3" model as inexpensively as possible but would consider simply adding a 2nd 2" I would especally favor used. Any leads to a truely affordable solution will not only be appreciated but if your local I'll buy you a beer!
Aug 27, 2007
12
- - Pasadena Md
Heat Exchanger replacement/upgrade
Since no one responded I will assume there are no affordable alternatives to the costly units available.
Bob, the only people who make them are Universal
because it's the "marination" part of converting a tractor engine into a boat engine. Since that's the key component, there just are no alternate sources.
Apr 1, 2004
185
Catalina 34 Herring Bay Chesapeake, MD
Universal HX Possibilities
Bob, Try these three sites, Marineparts will provided addirtional quote via email. http://inetmarine.com/ http://www.marineparts.com/ http://www.go2marine.com
F
FLipsky
Heat exchanger replacement
I have a 1984 c-30 with the universal diesel 25. I replaced my heat exchanger in 2005. My boat had the original 2 inch model and always ran hot under load. I upgraded to the 3 inch model and it runs great! I bought the unit from Lenco replacement coolers. They are located at 690 Albany Ave. North Amityville, NY 11701. 631/842-4049 Web site: lencocoolers.com They are a pleasure to deal with. Just tell them your engine and they will advise you with unit would be best for you. They manufacture them on-site and have most in stock. Their prices are more than reasonable too. Good luck..........Frank (First Luff)
