Before I change the thermostat, troubleshoot wiring\guages\senders, I'd like to run this by this forum.
Universal M-18 takes forever to warm up. After a hour of power-boating, still reads 120 degrees. 2 hours gets it to 180.
It seems that a thermostat would stick closed, not stick open, and with FWC there should be less gunk in there anyway. I haven't opened it yet, no replacement gasket on hand.
Would the sender\guage\wiring resistance be a common culprit?
The Raritan hot water heater has the plumbing arranged to enable bypassing the heater, by simply turning a gate valve. Has anyone used this technique to warm the engine faster, or does it matter? Seems that the heater is also a huge 6 gallon heat exchanger.
If the heater is bypassed for quicker warm up, what would happen if the loop was opened again during running. Would the rush of cold coolant cause any harm.
Anyone with this or similar setup and experience please comment.
Thank you
Thank you
