4000 hours and going strong.
I own a Dodge with a diesel and a c-36 with a universal diesel.I have almost 4000 hours on mine M25, just give it good clean fuel, good clean oil and change the zincs inside the heat exchanger.Warm the engine before you use it, let it idel after using it to cool down.The engine will last longer is started and run for a long time, short hops are hard on it, mostly because the oil and all metals have not come up to full operating temp. so many chemicals, and gases have not had a change to expel themselfs.Warmup, cool down. change oil every 100 hours or every year. Use good diesel oil and a good water seperating fuel filter. Always store your boat with the fuel tank full, less condinsation.EnjoyBob
