Hi,
On my 1982 Catalina 30 with a Universal 5411, I found water in my oil. I flushed it with new oil and am l removing the timing cover. I purchased a new shaft oil seal and gaskets but wonder about removing the square plate that holds the throttle governor. Must I disassemble that tower, or do I just pop the plate and unhook anything beneath it? (Can I ?)
Also, the oil filter looked dry and I figure the oil pressure relief valve might be gunked with the sludge formed by the oil water mix. The valve does not seem to be in supply. Can it just be unscrewed, cleaned up and replaced?
Thanks for any advice on my next step as I plan to remove the square plate and the timing gear cover shortly.
Bruce Adams
sailbruce@aol.com
631 261 9811
Bruce Adams
sailbruce@aol.com
631 261 9811
