I have a 5411 in my Catalina 30. Runs well... temp is good when running for a while. The exhaust is mostly steam as it gets warmed up. It occasionally spurts water in the low /mid throttle range. If I throttle up, the water spurts become more frequent. All seems to be working well...
Then a friend saw me motoring by and told me I that my engine wasn't discharging enough water and I should check my intake. I will... and have recently gone through it and it all seems good.
But now I'm curious - for you 5411 drivers out there - what's a typical water discharge for that engine? Perhaps it depends on where you are - my water temps are generally about 55 - 65 degrees.
