mark stevens
On the bottom of my timing chain cover there are 2 almn. press in tapered plugs originally installed to close off holes used to gain access to internal adjustments. One of these plugs has semi-rotted out and now I have a fairly profuse oil leak when the engine is running. I tried filling with 5200, liquid metal ect. and all failed. My problem is that there is only 5" clearance from bottom of cover to bilge. Rather than remove the engine and pull foward to repair - I have used right angle drill attachment and drilled the 3/8 plug out completly using a mirror.(Now I know how my dentists feels)My question is I am not sure what type of tap to use now that I have the hole. Should I use a 1/2 pipe thread tappered tap? and a tapered course thread bolt?
