Died after only 2 years?
Something doesn't sound right.Batteries should last longer than 2 years. My group 24s and 27s lasted about 7 years.How far down do you run them? Even though they are deep cycle, that doesn't mean you can run them down real low. If you switch to 4D or 8D, they are not going to last any longer if they are not used correctly.They should never be discharged below 50% of their capacity. Discharges to less than 20% of capacity can be very damaging, and may never recover.Did they ever get cooked dry? The plates should never see air. Exposing the plates to air is fatal. The portion of the plate that drys out in the air is permanetly out of action. Even if you cover them with electrolyte again. If you have always used good practices when on battery, and they still are dying young. then check your altenator and battery charger. I assume you know that when you have a good battery connected along with a bad battery, it does not bring the bad one up to the good. It actually brings the good one down to the bad.Or, you could just have a defective battery. A great book is "Living on 12 volts with Ample Power" by David Smead and Ruth Ishihara. They have 2 books out on 12 volts, and they are my bible.
