Steve
Electrical circuits are not one of my strong points and I am having trouble figuring out how Tranquility (2003 H356) is wired so here are some questions. Any and all help is greatly appreciated.First: The DC schematic shows, I think, that the bilge pump is connected only to battery #1 without regard to battery selector switch position. Am I reading it correctly.Second: How does the battery selector switch enter into battery charging, e.g., if the switch is on #1 is #1 the only battery getting charged. On my last boat (O'Day 322) both batteries were charged without regard to the selector switch position.Third: Where is the 30 amp galvanic isolator located?Fourth: The schematic shows a 300 amp fuse near the batteries. Is that the small box on the bulkhead just forward of the battery box? Where does one buy that fuse?Fifth: What battery selector switch position do you use when (1) at dockside with AC power to the battery charger (2) at dockside with no AC power for charger and (3) when motoring. Thanks.
