Under Counter Water Filters
Sep 9, 2013
16
Beneteau 373 Stockton, MO
I would like to install under-counter water filters on my 2005 Beneteau 373. Alternatively, I would like to install one immediately before or after the freshwater water pump under the starboard settee bench. The water filters I have located in hardware stores do not have the fittings I need for my standard Beneteau plumbing. Any suggestions???
Jan 4, 2006
7,771
If you can describe the filter fittings and the Beneteau fittings, the adapters do exist to allow them to match. Let us know, and we'll let you know the adapters.
Gunni
Mar 16, 2010
5,937
Depending on the plumbing fittings installed on your boat you may have install plumbing fitting adapters. You have lots of filtration options, but for boating the Seagull IV system is ready to go. They are very easy to winterize. You can decide whether you want to size up for whole-boat or just POU (point of use, like galley sink)
