Dave
I have an older R-12 A/B "Cold Machine" Refrigeration Unit on my 1992 Hunter 35.5. Beginning last season, I noticed the unit was not cooling as it had in prior years. The problem continued this year so I had the unit checked by a serviceman authorized to work with the now banned R-12. The problem points to the compressor and not to a leak in the system. Now, my questions:1.Can the compressor on the older units be broken apart to check/repair the seals? 2.Can just the compressor be replaced? 3.If a new compressor is not compatible with the R-12, can the R-12 be bled out of the existing lines, add new enviro-friendly approved refrigerant and then install a new compressor. My objective - besides cost - is to avoid replacing the lines and the evaporator if at all possible as the lines are very difficult to get at.I look forward to and thank you for your response.Daves/v Compass Rose
