Need to bring the mast down on our '23 to replace windex, add VHF antenna, add anchor light, add a spreader mounted deck light, and fix the steaming light. This will have to be done at the slip as I don't have a trailer. Should I bring the mast down foward or aft? Also, are there any special tricks to bringing it down? I'm figuring that if I release the forestay and pull the forward hinge pin then have a friend walk it aft holding tension while I and another friend 'walk' the mast down should work. Then it's a simple matter of pulling the aft hinge pin and laying the base of the mast on the bow pulpit. Then I should be able to get to the masthead and spreaders from the deck. Yes/No???
