Ultrasonic Cleaning of Stainless, how to and re-passivation?
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
I have all standing rigging off for the winter, and wanted to clean up and re-passivate much of that rigging, including turnbuckles and mast plates. What should be used for chemicals in the ultrasonic cleaner, and then how to re-passivate?
I will continue to research, but thought it would be good to post this topic for sharing. Who has the metallurgic background and experience? I definitely don't want to create any long term issues.
The turnbuckles may not be stainless, they are often chrome plated bronze.
Mar 26, 2011
3,739
Corsair F-24 MK I Deale, MD
Correct. Turnbuckles are virtually never stainless, except on dingies. Stainless is very prone to galling when tightened under load.
A 1 hour soak in 10-15% citric acid at about 150F is a good passivization method. Many variations. Longer times can replace heat, higher concentrations don't help.
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
Great point, mine definitely aren't.....
....any issue with giving them the same wash treatment?
Here is what I found so far:
How To Passivate Stainless Steel Parts
Process 1 for Austenitic stainless
Cleaner/Degreaser
Water Rinse
Passivate per Fig.4 (10% by WEIGHT citric acid, 150F, 30min)
Water Rinse
Dry
Apex
Jun 19, 2013
1,212
C&C 30 Elk Rapids
Thanks Thin! Exactly what I found with the Googles.....My ultrasonic cleaner has heat, so 150F it is for 30min...
On brass I have used a mild soap water solution in an ultrasonic cleaner. Cleans the grime and dirt away to bare metal.
Likes: Apex
Mar 26, 2011
3,739
Don't ultrasonic clean for more than a few minutes. That can do damamge on its own and is not needed or helpful. Just a few minutes. For SURE don't unlrasonic clean the turnbuckles, unless you want to risk pealing the chrome or loosening inserts.
I have an ultrasonic cleaner, but most I used it to torture test and destroy certain parts as part of a QC process. Like power washers, they should be used with extreme restraint. I'm not a big fan for cleaning.
