Jack Betts
On our 1981 h37, we've got a Wilcox-Crittendon Imperial Jr. toilet with a 15-gallon (nominally, anyway) holding tank next to the toilet. For years we had a y-valve and and Gusher-type pump so we could either pump overboard through a thru-hull, or up to the deck for pumpout. We wired the thru-hull shut years ago and have pumped out, but it has always taken a long time to get a thorough pumping out. Now we're getting nothing out, and I suspect the reason is a thick clog at the bottom of the tank. The air vent is clear. In trying to get at the problem this weekend, I removed the Gusher-type pump, the Y-valve and the extra hose that went to the thru-hull. That left us with a straight shot from the bottom of the tank to the deck-level pumpout, but we can get only a little waste out. The tank itself is full -- in fact, so full that if you were to pump any water through the toilet, the pressure forces liquid waste up the vent line and overboard. Seems obvious to me there's a big ugly clog at the bottom of the tank. My plan of action at this point is to take the hose from the toilet to the top of the tank, run in a smaller hose, and pump waste out and into a 5-gallon jug that I'll empy appropriately. Once I get all the liquid waste out, I can then cut the line about 6 inches from the exit at the bottom of the tank (can't yank it off the tank fitting because it appears to have been epoxied on at the bottom by a previous own) and go in with some sort of pooper scooper and remove the clog, or whatever it is. At least, this is my plan after trying everything else yesterday. Anyone have a better idea?Jack Betts
