Peggy: I've had a couple of episodes now in the past few weeks where what's in the waste tank appears (while the boat is closed up) to be backing up out the toilet into the floor drain in the head and going to my bilge. Not to put too fine a point on it, but when I lift the floor board to access the bilge, I'm finding a pool of waste with a nice sheen that's formed across it. Then I have to run the bilge pump and clean the mess. What would cause this mess to back up in the toilet (not a porta potty) and create this problem? My waste tank is by no means full (I just had it pumped out). I've alternately left the handle on 'wet pump' and 'dry pump' just to see which would make a difference but in both positions I'm getting this back-up into the bilge. This is getting embarrassing.
