I am replacing my standing rigging U-bolts on my 1982 Hunter 27.
Question I have I bought Win chard U bolts the same size as my previous one which I am sure were original. However upon installing them, I come to question the length of the threaded bolt
through the hull. When installed with the SS Washer and locking washer there is only approx 1/8" of the bolt protruding from the nut. Which was the same as the previous U bolts. Is this enough or should I pull them out and order longer bolts. Any help and thoughts wold be appreciated. If this is not enough then the previous ones were incorrect as well. I am questioning the amount of threads needed to be exposed in order to have the holding power needed. Also does anyone know if there are any torque specs for tightening down these bolts?
Wesley
Wesley
