Prop Choices
I have some personal experience, over 15 years, with a two blade fixed, a two blade feathering, and currently a three blade "sailor" fixed.
Sidebar: please do not imagine that "racing" is relevant. Whether you enter a race or not has nothing to do with your problem. Efficiency under sail and under power is the issue.
By far, and I mean a knot of speed gain in all wind speeds, the feathering prop is
the best answer for
sailing. It's a mechanical device, though, and has its own maint. requirements, beyond the high initial cost.
Fixed props are a the same or maybe a little better for motoring, and I now find that the
three blade fixed is way better than the two blade I used to use.
Even though we went with the narrower (sailor model) blade version, the increase in power delivered to the water is
very noticeable. If you are in a steep chop in a channel where sailing is not practical, the added power is wonderful.
I have a bit more waterline than you, but about the same displ. We might even have the same diesel, an M25XP Universal.
So be prepared to love the motoring performance and realize that there's a price to pay when under sail. Everything's a compromise, as someone once said...
We now motor, with a clean bottom, at 7.5 kts, and can maintain an easy cruising 7.0.
Advice worth about what you pay...
Best
LB
