YES, but......
When ever any metals come in contact with an electrically condutive path( sea water) you have a corrosion cell (rust) which in effect becomes a battery. This is normal.In your case the electrically conductive path would be the sea water. The stainless steel usually is higher up on the galvanic scale than the brass. This means that the stainless steel becomes the Positive terminal and the brass becomes the negative terminal.So now the electrons and ions flow from negative to positive, which would be from the brass to the stainless steel. What does this mean...the brass would deteriorate or rust faster than the stainless steel. The good news is that they are both somewhat resistant to corrosion and will last a fairly long time and also the zincs that you put on your prop shaft will also lose these little particles to both the steel and brass.Since you can not eliminate the corrosion completely, i wouldnt be concerned especially if they are not in direct contact with each other.
