Jason, I assume you DO mean "twisted", not "bent"? If you have the H23 manual, Hunter reccommends putting a slight fore-and-aft prebend in the mast by selectively tightening the upper and lower mast stays (I bet I get alot of feedback on that statement!). I haven't played much with this adjustment yet, but from this forum, I've come to understand that it makes a big difference in the boat's tracking ability and resistance to weather helm in stronger winds. Anyway, if you really do mean "twisted", i.e. one spreader tip is further foward of the other, then I would say that you have a problem. If you sight up the luff groove, twist and/or side-to-side bend should be obvious but non-existent. Hope this helps...
