Twin head waste systems
71
Irwin 37 c.c. Cutter indian rocks beach, fl.
Hi Peggy, My Irwin 37 has 2 completely seperate head systems and all the 1.5 inch hoses need to be replaced. The rear head works fine(rebuilt) but all the hoses look original from 1974. Has 2 bladders(ok) and 2 non working manual pump outs(unrebuildable due to corrosion). Should I keep it the same setup or can I combine the 2 to save on materials and simplify? Should I keep both heads intact or take one out and use the space for storage space(closet)? I plan on longer trips later on but at this time just run out in the gulf for day or overnight trips. I will post pics later. Thanks, Jim
Dec 2, 1997
8,952
- - LIttle Rock
I know what I'd do if it were my boat...
But first some questions:
What is the make/model of the toilets? How old are they?
How old are the bladders? Brand?
How many people typically will be aboard overnight?
Let's start with that much and then see where we need to go from there.
