Turning turtle
E
Edwin M
Just got this off Scuttlebut (www.sailingscuttlebutt.com), sounded pretty good so I thought I'd pass it on. I could not get the image to come up but I'll try again. Let us know if you have any luck. SAFETY When a small sailboat capsizes, the masthead is immersed and water begins to intrude into the hollow core of the mast extrusion. This progressive flooding causes an increase in capsizing moment and the boat eventually turtles. When the boat is righted, the added weight of water must be lifted clear of the surface. Once the mast reaches horizontal, the water begins to flow toward the step. The reduced capsizing moment quickly drops well below the applied righting moment and the boat snaps through vertical, often to capsize again on the opposite tack. This could result in the crew becoming trapped under the sail, which is definitely not good. The Chicago Corinthian YC solved this problem on their 420s by inserting closed cell pipe insulation into the masts, at a total cost of the project was something like $6.00 per boat. The process with pictures is outlined on the CCYC website: www.corinthian.org/junior/Retrofitting420Mast.html
Dick in MI
Foam and other remedies
I've heard of folks putting foam in the masts of their 170's. I personally use the Hobie float at the top of my mast. Between the Hobie float ("is that some kind of weather staion up there?") and the open transom ("doesn't water get in your boat that way?") I never am at a loss for questions from bystanders at the launch ramp.
Rusty
Hobie Float
Dick, Do you also have a Windex on you mast? I have not used the Hobie Float, but my kids are starting to push me out of the boat. I really don't want the boat to turtle on them, but I also want to keep the Windex. I have envisioned a few mounts for the Windex, moving it over or up/over, allowing for the installation of the float, but why reinvent the wheel? Advice is appreciated. By the way, I did get my shroud adjusters ordered and hope to install this weekend. We'll see what happens. Rusty
Dick in MI
I don't have a windex
The instructor who taught me to sail took great pains to make me read the wind on the water and it paid off. There are times when the wind is shifting continuosly that I wish I had a windex, but the trade-off of the windex for the float is an easy choice for me.
