Another possibility
We bought a H380 two years ago and when we brought the boat home it always wanted to go to starboard very quickly. Dealer said it was prop walk. I changed the prop for a Max-Prop which I was told would not be as bad. Even after the prop change, the boat went quickly to the right. Hunter sent a vice president to investigate and although he was a power boater, he did agree something was not right.I measured the rudder when I hauled to change props and found that the rudder was NOT symetical, but was concaved on the port side and fatter on the starboard side. Hunter agreed to change rudders and the problem was eliminated (given the Max prop and the new rudder).Since then, several people have measured their rudders and found similar problems. I would recommend to measure your rudder and do not just accept prop walk. If your rudder is not symetical, you will lose speed and have steering problems.
