L
Leo Irakliotis
I am the second owner of a 1990 Hunter 30', without the original manuals and with the following question:Once the engine is running can I turn the ignition key to the off position and remove it from the panel?The reason I would like to do this is the following: I went through two keys already! Twice a guest has broken the key leaving half of it in the switch! Not that I mind the 5 minutes that it takes to unscrew the panel, to remove the broken piece, but my locksmith is charging $8 per key!I am asking if it is ok to turn the key to the off position with the engine running because I was told that this may damage the alternator. Is this the case in the 1990 30'?Thanks, -leo i.
