Tighten the backstay .....
If the forestay is loose and sags off to leeward, most boats will have difficulty in 'rounding up'. To tension the forestay - tighten down on the backstay. Proper forestay (backstay) tension will be such that when you are laying flat on the deck with your eyeball looking straight up the forestay - on a hard beat to weather in about 15 kts - the forestay should sag no more off to leeward than about 5-6 inches max. Any more sag than this, the boat will have excessive heel, wont point, wont round-up, .... will be slow as molases. If you have a tension guage the backstay tension should be 20+% for beating to windward (12% tension of 'all-around' sailing). :0)
