This also happened last spring. Volvo MD17c that I rebuilt 5yrs ago.. Smoke out the middle air intake. Removed the middle rocker cover and found a bent pushrod..Removed the middle head and machinist stated it could have been a valve hanging up. Reinstalled and ran all last summer up to the Broughtons and back for two months. Got back first week of last August and parked the boat to do other things. Started it up in Jan and ran fine. Started it up a week ago and KAPLOYEE/KABOOM...Ok, based on previous experience, removed the middle rocker cover and bent pushrod...Replacd the pushrod and turned engine over by hand to adjust and bent another one...Another pushrod and everything adjusted and engine ran fine...OK, so off came the head today and going to a head shop tomorrow. I put a mirror over the jacket and shined a flashlight to the tappet. Broken!! Appears that the upper rim is broken and some metallic "stuff" off to the side...I did have two known straight pushrods and rotated engine by hand to verify they both moved "same amount" which did....tomorrow is machine shop and try to extract the tappet with a magnet...i may have to move the jacket up to see if the tappet guide is scored....Hmm..so did a slow moving valve cause the tappet issue? Or did the tappet issue cause the pushrod problem? We'll start by seeing what the machinist says..Fortunately, I have a lot of spare parts from an engine given to me..one pushrod is $92...only two left. I'm pretty good with engines but this is baffling....
