Everything you wanted to know about stainless
Ahoy Steph,It depends on the temp and the type of stainless used.The following general rules apply:304 may be used for fully exposed components, frequently washed with fresh water; 316 may be used for all hull and deck fitting applications above the water line; S31803 offers higher strength and, therefore, lighter weight components for the same applications as 316 and can additionally be used up to 60çC in wet exhaust systems and in fully submersed applications; and S32750 offers even higher strength and weight savings, and can handle all marine applications with no risk of corrosion even in tropical waters and hot, wet exhaust applications.While stainless steel grades 304, 316 and duplex steels can all be used in marine applications, they do provide varying degrees of corrosion resistance and durability. The key to their successful application is, therefore, being aware of the strengths and limitations of each grade and how they can be used to their optimum potential.The corrosion resistance of all stainless steels also improves if they are kept clean. The build up of salt encrustations, grease or dirt allows corrosion to occur in these regions. After use in marine situations, it is good practice to wash down with clean water and to remove any deposits on the surface.Fair WindsCap'n Dave
