Hi All:
I would like to be able to set the valve clearances on my Yanmar 4JH4E. To do that I would like to position the crankshaft accurately by turning the engine manually, say with a large socket wrench on the nut holding the v-belt pulley on the end of the crank. I find that touching the starter to move the crank is not very precise and the engine will start running sometimes. Has anyone done that? Should I expect to be able to do so?
Thanks
Thanks
