Mast bend
All generic mainsails have a certain amount of depth or chordline built into them....unless you have a specific custom built sail that is flatter....ie. racing sails. Now, to address some of you comments..1."Trying to bend or incline 6 degrees is going to be difficult to measure, and it begs the question "6 degrees from what line?".a. Your speaking of two different things...mast rake and mast bend are two different things....mast rake is the amount of incline measured from the mast against being verticle when the boat is in the water.....it is measured in degrees and not inches, Mast bend is the amount of bend invoked by tensioning the upper shrouds....about 2-3" is good, and can be measured with the halyard held at the base of the mast.....yes this does create compression on the mast and if you had a giant hand and pressded down on the top of the mast you could create more mast bend....to prevent this further movement....you use the lower shrouds to prevent this by pulling the middle of mast back to prevent further bending...ie. freezing in positon.2. "Just out of curiousity, where is the bend located in your mast? How did you arrive at the idea that 2-3 inches of mast bend is beneficial to sail shape? Don't get me wrong, I bend my mast, but only with the adjustable backstay. I do not have a furler."a. My mast bend is basically in the center of the mast.......a certain amount of mast bend helps flatten the belly of the sail...if you were to lay a sail out flat on a large flat surface, you'd notice that the middle of the sail would seem to have a bit more bagginess to it....thats because there is extra material in the center.....if you pulled the center from the luff and leech, you'd notice that the luff is no longer a straight line but more of a slight curve.If you only bend your mast from the backstay, you are in effect reducing the shrould tension and on a reach, you'd notice the lower shrouds of the leeward side go slack to an extent. this amount of wobble in the middle of the mast is not the most effcient to getting the most out of the boat.
