L
Leif Arneson
The foot of the mast (forward end - opposite the retaining pin) on my hunter 19 (93-96) does not seem to be in full contact with the tabernacle. When the rig is defected fore and aft (as for example done by tensioning the topping lift) the opening visibly widens and closes, is this correct? Also, my forestay turnbuckle is two-blocked and therefore the mast’s rake can not be reduced to close this gap without developing excessive forestay sag. Mast bend, rake, upper and lower shroud tensions are all otherwise as close as possible to those recommend in the user’s manual.
