The first thing is to find out what size wire you have. This sets the maximum tension allowed. This will apply to rigs that are left up full time for boats similar to yours. Start by adjusting the uppers for proper mast bend and tilt port/starboard. then, snug up the lowers by hand. Then, tighten the uppers and lowers evenly, maintaining proper bend and tilt until you reach ~10% of that breaking strength (that is about 230 lb for 5/32"). Go for a sail in moderate winds and see if the leeward shrouds get floppy. If they do not, your tension should be pretty close to where you need them. If not, tighten them about 1/4 turn at a time until they no longer 'dangle'.
