Tuning B&R rig on Hunter 310
20
Hunter 310 Virginia Beach, VA
The upper diagonals (those attached at the top of the compression posts and the spreader) are very slack on the Windward side when sailing. This seems to go against regular rigging adjustments since they are slack on the windward side. Should I adjust a few turns until the slack goes away and then repeat the same number of turns on the other side after tacking over?:confused:
Dec 2, 1999
15,184
You should check your owners manual. Some of the B&R rigs are designed to be tuned on a bench and then stepped on the boat.
Morgan 41' Classic Gulfport, MS
Go to resources
tab above. Open it and look in the resource library on the right side of the page. Discussion and instructions related to B&R rig.
