Deucer
Well folks,Finally got out to tune the rigging on my H260. George, thanks for the info on your site. A couple of things I found. 1. I've got a Charleston Spar Mast. Sighting down the mast, there is a built in aft rake. Probably 6 inches or more.2. My D2 shrouds don't have a turnbuckle to adjust the tension. I'm assuming that as I adjust the lower shrouds, the D2 shrouds will tighten up.3. I don't have the rubber thingees where the shourds come out of mast. Mine are all stainless steel.4. My step appears to be different from the one on Georges web sight.5. I noticed when I'd raise the mast, that it would sometimes twist. I figured out that hole in the mast where the mast pin goes through was 3X as large as the pin. That allowed the twist. I'm planning to put in a piece of reinforced rubber hose in the hole to serve as a flexible sleeve (just like the holes in the step)6. Another clue that I don't have an original mast is the fact that I can't tune to the required tension. V1 on both sides max out the turnbuckles before I get to 37 on the Loos gauge. Guess I'll have to have a rigger shorten the shrouds...more money..sigh..I also built the PVC roller furling holder I saw in the improvement sections. Seems to work like a champ. I think it's going to speed up stowing the mast. I also plan on making Sunbrella bags for the halyards to protect them from the elements. I'll post pictues.Think that's it. Any comments?Deucer
