Tsunami
2,422
Whitby 55 Kemah, Tx
I'm watching this show on NGC about Tsunami. It talked about one that happened I think in Alaska in 1958. A landside dumped a lot of land into a a narrow body of water which produced a wave over 1,000' moving at 70 mph. There were 3 boats in the area. One boat survived. The survivor said that they were anchored when it hit and that they just started the motor and headed directly into the wave. He said the boat just rode up the 1,000' wave and down the other side while breaking the anchor chain. Now I'm under the impression that science says a boat can't go over a wave of 70 degrees that is larger then the boat because of the gravitational pull on the boat can't be overcome by the engine. Wouldn't a Tsunami wave be steeper then 70 degrees?
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Saw it
That was a cool show.....hate to have been that man and his son, however luck was with them. Sometimes things work out for no known reason exect being in the exactly right place at that split second of right time...... Sort of how I found my wife and boat. Greg
Ross
Jun 15, 2004
14,693
Apparently not.!
Probably need to go to the books concerning that earthquake.
Mike
2 links to info
http://www.usc.edu/dept/tsunamis/alaska/1958/webpages/lituyacloseup.html http://www.drgeorgepc.com/Tsunami1958LituyaB.html
