Trying to find matching Mahogany plywood
Apr 22, 2018
16
Hunter Marine 33 Penetanguishene
Does anyone know where i can get some plywood or veneer to match the interior wall panels of a 2006 Marlow Hunter 33
Apr 22, 2018
16
Buying any old veneer wasn't the question. I bought two different veneers my woodworking buddy says that the veneer hunter used is 1/4 cut veneer. I want to find out if I can get that. Any idea what company hunter Marlow used to procure their materials when building these boats? So I can ask the plywood manufacturer what species of mahogany I need to find in order to color-match the stain. Or do they still produce the same marine plywood used then?
I sanded a portion of the original wood and have color-matched it but the veneers turn too dark hense I need the proper vaneer for a good match.
Jan 4, 2006
7,306
Are you sure the walls are mahogany ? In 1999, the walls were teak. However, Hunter may may have changed to mahogany by 2006 ?
Jan 4, 2006
7,306
She's as cute as can be ! No question there.
However, would need a close up within a few inches of the panel to get a better idea of what it is. Pretty sure the solid wood around the sink is teak so the plot thickens.
DArcy
Feb 11, 2017
1,772
Islander Freeport 36 Ottawa
It looks like you are in Ontario, have you called Noah's Marine? They don't list mahogany but they may know how to match your panel.
Apr 22, 2018
16
I brought the panel and my made one there they ordered and sent me Mustard stain from Mohawk
the color matches the original when we sanded that piece and applied its a match but I cant get the new piece to match friend is saying the wood must be a different variety
DArcy
Feb 11, 2017
1,772
If the grain doesn't match then it could be a species difference, or just the way it was cut. The folks at Noah's would know better than I.
May 9, 2020
161
Hunter Legend 37 Harrison Twp, MI
According to the owners manual for the 2005 H-36 (page 30) it should be teak. They actually give a good description of how to repair/refinish:
DArcy
Feb 11, 2017
1,772
We could check in with our resident expert.
@TomY any thoughts on the above would grain question, how to match the existing material?
May 7, 2012
1,567
Hunter e33 Maple Bay, BC
Sailboats under Marlow Hunter started manufacturing in 2012. The year Hunter Marine LLC underwent Chapter 11.
Marlow Hunter 33 wall panels are finished using Mohawk Cherry Wood stain. The Amber Cherry plywood came from Vendor MIN234. I do not have a cross reference to the actual outlet. The nice folks in the Sail Boat Owners store maybe able to help. I have an Cherry Wood refinishing document that gives part numbers that I will send if you wish to PM me.
NOTE: If the the boat is a 2006 Hunter 33 then disregard this post.
TomY
Alden Forum Moderator
Jun 22, 2004
2,769
Thanks, DArcy. Sounds like the OP is looking for the original material spec. I know of sources for marine plywood like mahogany, teak, but I don't think that's what he's looking for.
Apr 22, 2018
16
replying to marmalade I have that in my book too
but it doesn't help in the replacing a panel question..... and Hello below yes its a 2006 thanks for the cherry stain reference I will message you and I do have an email sent off to the store people thanks
