V
Victor Robert
Thanks for your input on my last post. I checked the compressor windings' resistance, which was in the specified range and installed a new AB3016 electronic module. The problem persists. Every 20 seconds the DC current draw jumps by about 7 amps for two seconds, producing a high pitched whine, the fan stops, but the compressor does not start. This is the refrigerator unit. The identical freezer unit runs for a few hours and then goes into this same mode. They both started experiencing problems a few weeks apart.These are original model DCM 12L Cold Machines on a 1991 P42.Supply voltage is 13.0v at the control module terminals, and drops to 12.8 when the compressor attempts to start. Resistance between the bottom and top pins on the compressor is 3.6 ohms. Between the bottom and side pins its 0.3 ohms. I attached the new control module remote to the compressor unit and determined that the high pitched whine is coming from the compressor case, not the electronic module.Any further suggestions ?
