G
Gary Kunkel
We've recently purchased a Catalina 30 after many years of chartering 34 and 36 foot Catalinas. My slip is directly across the prevaling breeze and not far from the leeward end of the fairway (there are two slips between ours and the solid leeward end). I used to think I was good at maneuvering under power, but backing out with a good cross-wind breeze these days has been a real problem. As I back out, I usually just back out and down to Port (the direction the stern prefers when in reverse), put the helm over, gun the throttle and am able to spin the boat to Stbd and head out of the fairway. However, when any breeze is blowing, I back out and the bow immediately falls off to leeward faster than I can correct for (even using all the "spin in place" or "torque turns" that normally work). No matter how I try, the bow just will not come up into the wind as fast as needed.Any hints on how best to get out without damaging our boat or others? I'm familiar with using the normal prop walk to help get the boat spinning. It just doesn't work in this situation with the breeze up. My guesses as to how to get out properly involve maybe backing out and backing to stbd, followed by backing all the way up the fairway (into the breeze stern first). I suppose I could also back into the slip at the end of the day, then just head out for subsequent sailing days. Getting in is not a problem, it's only getting out when there is a good breeze. I'm interested in hearing from other Catalina 30 owners who may have found a solution (aside from the obvious one of changing marinas and finding an into-the-wind-slip). All suggestions welcome.Gary KunkelFolie a DeuxChannel Islands Harbor
