Entering Sarasota Bay
Actually, you can safetly enter Sarasota Bay from the south via New Pass. However, you need to stay to the south side as there is shoaling on the north side of the channel. Do not stay on the greens, or you will run aground in 1 foot of water when you approach shore.I go through the pass all the time and have found that as you return, you will see a sailboat mast of sailor who was not familiar with the shoals on the south side of the pass. The best thing to do is to actually head towards the sunken sailboat, but be sure to pass it on the northside. It went aground while on a S.E. heading into port, so if you keep 50 yards or so to the north of the sailboat, you are fine. Treat the sunken sailboat as a red marker.Once you pass the sunken sailboat, head towards the big houses on the beach in an Easterly direction, but don't head N.E. and you will be in 7 - 15 ft. of water the rest of the way in.New Pass was dredged in 2001, but they did it as a straight E - W channel and New Pass has always had a half moon curve around to the south.Within 2 years, the northside has indeed filled in. I don't know why they didn't follow the natural contour of the pass - your tax dollars at work. Bill
