Tri-boat
Tris always remind me of a bike with training wheels. You can't beat a multihull for crusing barrier islands in the tropics. Mark is right about them not being self-righting. Having no ballast is the main reason they are so fast, though. The main advantage of not having balast is that if it does flip, unlike a ballasted boat, it will stay on the surface (with your supplies). Besides, it's a lot easier for the CG to spot an overturned boat than a lone drifting crew member.The tri is a good compromise between a mono and a cat. As a cruiser (as opposed to a stripped down racer), it's not as stable or as fast as a cat. The big advantage is slip width (even possible trailering). But then again, if you can afford a Corsair, you should have no problem shelling out a grand-or-two-a-month for a slip, right? And speaking of price, did you know you could buy each member of a family of 4 their very own well equipped MacGregor 26M for the same price as the Cosair?If you're looking for a tri with even more speed under power (and trailerable), check out the Telstar 28:http://www.performancecruising.com/Default.htmI'll keep looking for my perfect proa.http://www.schachtdesign.com/proafile/primer.htmlHappy sail *_/),MArk
