Tri-lens radar reflector
Oct 29, 2005
2,362
I've a medium size Tri-lens Radar Reflector mounted about half way up the mast. Cruising chute and halyard do get caught on it occasionally but not a big deal. I was thinking of mounting the Tri-lens right up the mast as I've about slightly more than 1/2mtr of free mast space above the Cruising Chute rode mast exit slot.
Is this a good idea?
Mar 20, 2004
1,746
Ken,
Ours is about 3-4ft above the spreaders under our radome... putting it up higher might put it above the reflection range of other radars on smaller boats but other than that I don't see any real issue. more weight higher on the mast, but not an issue IMHO
Oct 12, 2014
42
Hunter 36 Port Ludlow
I spent 26 years in the navy operating just about any kind of radar you can imagine. Trust me when I say that on a pleasure craft of any sort, it would not be possible to mount the reflector high enough to interfere with any surface radar to see it.
Oct 12, 2014
42
Let's try that again in English. On a pleasure craft, it is not possible to mount the reflector high enough to avoid the vertical beam pattern of a surface mounted radar. To prove this, next time your see a helicopter buzzing around, or a low flying aircraft, just look at your radar. I guarantee that you will see the aircraft tracking on the radar.
Oct 29, 2005
2,362
Ok so the higher up I put the better. The standard Tri-lens weighs only 5.5lbs so I guess its not going to affect heeling much. It may even double as a flotation to right the boat when capsize? Just kidding
Mar 20, 2004
1,746
Panamax is correct - the vertical field of view of a typical recreational radar will certainly cover your entire mast
