traveling the carib
phil
my hunter has a holding tank at the present time. i am leaving for a year cruise in the carib.as far a venez. what type of system should i install for this trip ?
Peggie Hall/Head Mistress
What you have is all you need.
However, if you don't have the capability to dump the tank at sea--macerator pump and thru-hull, I recommend you install it. You might also consider installing a y-valve that allows you to choose between going to the tank or flushing directly overboard at sea.
