Scott
Hello all, I purchased a 68 MacGregor that has not been sailed since the early 80's. The person I bought it from knew nothing about it and was no help on what hardware was on it. I've had it out sailing a few times and cannot figure out what the proper setup for the mainsheet is. It does not have a traveler, but it has a double block running from the boom, a padeye and a single block located on the starboard stern corner and a pad eye and what can only be described as a swivel camcleat(?) on the port stern corner. Does anyone know the proper mainsheet setup and if I should replace it with a traveler? Any help is appreciated. Thanks, ScottP.S. It seems to heel quite a bit. Can anyone give me an idea on how far it will heel before rolling on its side or is that something you just have to do on your own?
