trapezoidal portlight replacement
2
- - Polson, Montana
Does anyone know how to get replacement trapezoidal portlights for a hunter 28.5. The exterior frames are cracked and damaged. The grey plastic windows are in acceptable shape. Is it possible to replace only the frame? Thanks Rob
Mar 8, 2004
22
Hunter 31_83-87 Eustis, Fl.
Trapezoidal port lts replacement
Contact Mark Plastics (909)735-7705 at 369 East Harrison St. Unit G. Corona Ca. 92879...I just replaced mine on a 31 hunter $200.00 per port light freight included....Looks great...you cannot replace just the pane, it just cracks to pieces if you try...Good Luck
