Starting a new thread set to the general interest category so I can capture the expertise of all forum members. Not just Mac26x. Could use some help creating my new transom extender for my Mac 26x sailboat.
Here's the original thread: http://forums.macgregor.sailboatowners.com/showthread.php?t=149685
I want to eliminate all the engine, rudder, and rudder connector congestion at the rear of the boat. Move all of that back to the rear of an extender with a platform.
I have read propaganda touting the benefits of extenders such as faster on plane, up to 25% better fuel economy, and 2-3 mph WOT speed increase. Is it true?
The platform welded, permanent top will be lower than the boat deck in rear. Over that a removable deck installed flush with the boat deck. In that space, the twin rudder connecting hardware and all wiring and steering cable will be located. The platform will be equal to the boat's stern opening 48", or should I go full stern width?
Should the extender be flotation type, perhaps 24" long? What about following seas?
The transom will be reinforced with aluminum.
http://s2.beta.photobucket.com/user/Chamelea26X/library/Mods%20-%20Transom
How shallow can one expect to run the outboard cavitation plate with a 24" extender? Setback and depth discussed here. 12:1 rule is it real?
http://www.ifish.net/board/showthread.php?t=288623
Mac26x boats have a bowup problem when trying to achieve plane. My nissan NS50d transom thrust rod is at the last hole closest to the stern/boat. Some owners have installed wedges to angle to prop more inward toward the bottom of the boat. Should I make the new outboard mounting plate more angled than the OEM stern? Or will the lever arm created by the extender be enough to correct this?
What kind of propeller pitch change will I have to do with the prop running in cleaner water? 10x10pitch great slow speed control but can over revs WOT and slow to plane at 15 mph at 5500rpm. Optimum for a nissan 50hp is suppost to be 11.5x11pitch. Got a 11.5x12pitch I have not tried yet on stock boat.
Think it is OK to mount my magma charcoal grill on a pedastal back there?
Suggestions regarding built in ladder design please.
thanx for your time!
