Thought they all had outboards!
I didn't know any H25's came with inboards, all the ones I've seen were outboarders.I bought my '83 with an old 2 stroke, 7.5 horse Mercury on what I think was the factory outboard bracket. I loathe 2 strokes, so I bought a new Honda 9.9 Power Thrust with 28" shaft & electric start. It weighs around 120 lbs, so I also installed a heavy-duty Garelick mount designed for offshore powerboat use. The engine was $3000 and the mount around $400. I used 1/2" Starboard on the outside & inside of the transom, and it seems plenty strong to me! It has zero deflection in it, unlike the flat transom on my Catalina 25, which deflects under the weight of a Honda 5 horse.I concur that if you switch to outboard that you pull the inboard out & "heal" the holes in the hull. I have a 60 pound air conditioner under the cockpit sole, and the combined AC/engine weight make it tough to trim the boat out properly. I can't really recall, but I believe the transom is plywood cored.
