Transmission
kair
Nov 4, 2008
40
Hunter 1980 H36 Kemah - Texas
Looking for help and advice. My transmission on my 2QM20 is really very stiff when engaging from neutral to fwd, fwd-neutral and same on the reverse.
Does anyone know what I should be looking for in rplacement parts?
Steve
Nov 6, 2006
10,104
Sounds like a sticky actuator cable. Sometimes you can lube them and sometimes you have to change them. Test by 1. engine off. 2. disconnect at transmission lever on transmission.3. lever should move by hand with medium effort. If it does, your cable is bad.(rusted or kinked or squashed ) . if it doesn't, then there is a problem in the shift index system on the side of the transmission. I wouldn't tackle that without a workshop manual.
Jun 2, 2004
5,802
Good advice from Claude. What about the oil level and age? Hasn't it been cold down there?
Jun 3, 2004
298
'79 Hunter 33' HUN33190M79L Olympia
Yeah, stay away from that transmission. It's the greatest, longest lasting mechanical device ever made!
