Don
My relatively new (to me) 1993 H37.5 has serious transmission problems. If you recall my previous post, it's basically not going into gear when I shift. It's not the linkage, because it actually is going into gear when I shift, and the shaft turns slowly. Just when I speed up, the trans does not speed up. It will engage at some point, but it's failry random. Generally if I bring the throttle down and speed back up it will be in gear. This problem has been getting progressively worse over the past few weeks with use.My mechanic says no one here rebuilds 'em (on the Chesapeake.) It's a "Kanzaki" trans on a 3JH Yanar. Says I have to buy a new one $2400 + labor to install. Yikes!Does anyone have experience with rebuilding these? Suggestions on who can do the work? Other ideas?Please help.
