W
Wally Smith
The shift fork on my 79C is worn on the forward shift side. Yanman guys in Ozz say the shift fork is no longer made. Engine and trans are probably original equipment. I had the fork brazed and cut but that was worn quickly, then I had it welded and cutback. Lasted a bit longer, Now I had to do the braze myself as Dili doesn't have a machine shop. Does anyone know a source for the fork? Transmission shifts hard and neutral is hard to find when the fork wears. The fork actually holds the discs apart and just gets out of the way when shifting. I'll be headed back to Darwin next week and hope to get this worked out.
