A
Allan Lansche
I have a 1982 Catalina 38 with a Universal Atomic diesel engine model 5424, serial number 311064. The engine will start and run fine but when I put it into forward or reverse and increase the throttle, the engine will die. Ican restart without any problem but when I put it in gear, the engine will die. All the filters have been replaced, fresh fuel, replaced the lift pump. I checked the prop shaft and there is nothing binding it that I can tell. Does this sound familiar and what can I do to solve the problem.
