transmission in reverse while sailing
Shaun
I thought that folks might find this response from Hunter Marine interesting..... Hunter Marine Response: Mr. Taylor, It is our recommendation that the transmission be sailed in reverse. This is also the recommendation from Yanmar. Greg Here is the question that I asked: > While sailing my transmission is in neutral... with the two bladed >prop I get a continous "thumping" sound from the shaft area.... I have >read on the hunter site that some place their transmissions in reverse to >stop it... I see nothing in the yanmar or hunter manual on this... what do >you recommend from a mechanical/maintenance prospective? >
BILL SHAKUN
why
What is happening is the prop is now the driving force rotating a gear system is reverse. What is the logic or better still what are the engineering negatives with this procedure. It appears the prop is introducing drag/friction into the dynamics of motion. Are they saying start the engine in reverse, or shift into netural before starting.
Jack Laird
A long answer
Archives have a long learned answer with pictures/drawings showing why the transmission should be in reverse. Yes neutral to start.
Terry Arnold
long and learned? source
http://www.c-2.com/upload/display.tpl?folder=Arnold73052126092&fno=17
K
Ken Palmer
Here we go again!
Yikes, please check the zillions of notes in the archives.
Bryan C.
Quick summary
The quick summary is that in neutral, a freewheeling prop causes parts of the transmission to turn without proper lubrication. It won't turn in reverse. Whether a freewheeling prop generates more drag than a locked prop has been debated, but the difference appears negligable.
