transmission fluid help
rick h
I recently purchased my 89 and am in the process of going through it, in it, over it, around it, and now i'm stuck with exactly how much trans fluid should be replaced when changing it. my manual only tells what kind of fluid, and i still haven't found the dip stick they mentioned. my engine is the m-12. help would be greatly appreciated.
L
lnranch
Transmission
Is your engine a universal? If it is the "dip Stick" is a bolt on the top of the transmission located behind the engine. The dip stick is on the bolt. To change the fluid you will need to vacum the fluid out. Good luck
