John Mavrovich
I discovered transmission fluid in the bilge a week ago. I removed the drain plug (wasn't loose) and verified that it was bone dry. I filled it to the prescribed level and ran it for a couple of hours (at idle in gear - fwd/rev) and went sailing this weekend - ran it at max rpm for an hour or so. Didn't leak a drop! I'm completely puzzled. Add'l information: Boat was in the water all winter as usual. During the winter months I run the engine at idle and in gear every 2-3 weeks. I keep a 60 watt light bulb below the M25XP diesel engine that clicks on when the ambient temperature gets close to freezing. Any thoughts would be most appreciated. Thanks in advance.
